Hi All. I have a 2003 Passat wagon 1.8T, FWD, Manual transmission with ABS errors on the dash. Also, the traction control light is illuminated. I used VCDS-Lite to see the fault codes:
01435 Brake Pressure Sensor 1 (G201), 48-10 Supply Voltage - Intermittent.
I have had a number of issues with the ABS in the past 2 years. Replaced the ABS wheel sensors a few times, and sent the ABS electronic module to a well known vendor for repair (twice) and I am still having intermittent issues. ABS functionality is disabled when the light appears, as you'd expect.
The frustration is the lack of information on these Bosch 5.7 ABS units. In searching for alternatives (rebuilt Dorman units-- I bought one I thought would fit, but no luck..., or new units from ECS Tuning, RockAuto, FCP Euro, etc.) there seems to be a lack of information on these units and only new units being sold.
The ABS electronic module has a part # 0265950081 - this is the Bosch part.
The hydraulic block has a part # 4B0614517P
My VIN is WVWVD63B73E074789
Does anyone have access to VW's ETKA to see if there is a new part number for the ABS Bosch part # 0265950081 ? Is there any Bosch database that shows which versions were used in various cars?
Thank you.
Thank you.
