1 - 12 of 12 Posts
I have a 2005 passat wagon with the 1.8t yesterday it threw a cel so i went to check it and i heard some clicking from under my seat and then my hazards flashed 4 times and the tool told me it couldnt connect, now the car misfires under boost. Has anyone had this problem before?
Its just an obd2 scan tool my work has
Just to eliminate a probable cause, try to connect that tool to another car and see if it works correctly. You just want to be sure that the tool is working right.
The tool works on my other car perfectly fine
It looks like you may have water damage to the CCM and/or its wiring.
I don't know if the links below are still functioning.
WATER INGRESS AND SOLUTIONS
It looks like you have a problem with the floor harnesses and grounds or the CCM, you can get this fault with or without water ingress.
Locate and fix source of water ingress, if any.
I suggest you completely unwrap all of the CCM harness and pull the wires apart to find the splices, any corroded splices need
to be cut back, soldered, and covered with marine grade heat shrink tubing. (You might need to add short wires to replace what you cut out)
Also check ground connections (1 on floor and on "A" Pillar), and check CCM/TCM and "A" Pillar connectors.
Have a good look at these links, before you start.
NOTE: The car in this DIY is UK RHD. (the CCM is always on LHS)
VW Passat CCM harness repair | HeadFUZZ
This thread attempts to bring together all the problems regarding water ingress and their solutions.
Water Ingress and Solutions
Another possibility is cracked solder joints where the relay is connected to the CCM PCB.
You will need to get this right before you can address the original issue.
Discussion Starter #8
I have just gone through and rewired the entire ccm so im really hoping thats not the problem
It's worth a look at the PCB at least. You're looking for a ring around a solder joint, basically.
Good resources:
Cold solder joint:
Cold and Cracked solder joints:
Discussion Starter #10
Good resources:
Cold solder joint:
Im not too knowledgeable on the acronyms what is the pcb and where would i find it in my car
PCB = Printed Circuit Board
That is the electronic board where all the components are soldered on. You may want to look at it carefully to see whether any component has got loosened.
Discussion Starter #12
Oh boy that sounds like a lot of fun I'll check it out when i get home.
1 - 12 of 12 Posts
