1 - 20 of 91 Posts
So this started happening out of nowhere. When I brake and come to a stop. The whole car shakes violently. There is no general area where the shaking is coming from, it’s just the whole car. My ABS light is on and the code I got was 005241 Brake boost vacuum system, mechanical failure. I was going to replace the pump but I decided to just take it apart and clean it. That only improved it by about ten to fifteen percent. I decided to make my own post because the other forums and threads that I’ve read don’t have similar symptoms, just the fault codes. I don’t know if it’s my check valves or pump or the actual booster. I want to fix it because having to put the car in neutral every time I come to a stop is not the most ideal situation, and traction control would be nice. Could use some help to figure it out.
A full scan with VCDS or similar would be a big help.
The only thing that can cause the shaking as you have described is a misfiring engine.
I suggest you check the link posted by AndreasPassat
Check all vac lines & check valves for leaks, and check all of the PCV system.
It appears likely that you also have a faulty ABS module, I suggest you send it out for repair.
Discussion Starter · #7 ·
I know it’s not a misfire. It only happens when I’m in drive. I’ll post a video. Pcv system was replaced a year ago due to the misfire. There are a couple check valves that I could replace but I’m fairly certain it’s not the problem. I’ll post a video if I can. I also replaced the abs module about a year ago
Discussion Starter · #8 ·
Couldn’t post a video. Here’s a link to where I uploaded it on YouTube. Hope this helps y’all understand it better. It’s hard to describe the shaking to where people don’t think it’s something else
Update. I cannot find the fuse. Also. Car shakes more when under electrical load. I turned on my brights and the shaking got worse. Then even more so when I turned on night lights and my light bar
Look here: Where is the brake booster fuse?
I would take a look at the alternator, too. Any strange noises? When running, measure the voltage at the battery with a multimeter and then switch those items on and see what the readings are.
I would try and get a scan done with VCDS. There's a check engine light on so I would wager to guess that is either contributing to or is an additional underlying problem.
Discussion Starter · #13 ·
Check engine light is for an 02 sensor wire. When I erase the codes the check engine goes away until the second turn over but the abs never goes away.
102585
102586
Go over the entire brake vacuum circuit. If there is a leak anywhere, it can cause the pump to run excessively, setting the code. Suction jet pump is a common break.
Discussion Starter · #15 ·
Just pulled hoses. No visible rips, tears, or holes. Sealed off ends and ran air through. No leaks
Disconnect the large connector from the ABS module, and let us know if that makes a difference.
Discussion Starter · #18 ·
Disconnected the module. Brake light came on. Pedal got more stiff. Shaking persisted. Don’t know if I just not started hearing it or if it got worse but there is a new noise.
That last video, what is that?
Mount the camera on a stand sitting on the ground pointed at the engine or the car body will a be a better testament as to what is actually 'shaking'. Is the car sitting on all 4 tires on the ground?
I can hear a faint tell tale sign of clicking, I'm calling it, the ABS pump is faulty.
I'll eat my words in the end if I'm wrong.
Have you put a vacuum gauge on the engine while it's running?
Ok, another thought. Did this violent shaking and the brake code occur at the same time? Many times, when someone posts something up and there are a couple of issues, it makes it sound to other members that they are related, so we try to find a common fault. Maybe those two things are NOT related in this case.
Have you by chance replaced the front axles with aftermarket axles recently? At a stop in drive, many solid aftermarket axles will cause the entire car to shake. That symptom has been well documented.
Reactions: AndreasPassat
1 - 20 of 91 Posts
