1 - 2 of 2 Posts
Hi. Does anyone have any ideas as to the drain and refill plugs in the gearbox. I can't see info about doing this procedure.
Passat 2000. 12. 07 AZM engine EMV 5 speed gearbox. And any workshop manuals this car?
Thanks for any help
The trans code does not matter as much as the model. If it's an 012 or 01W transmission, then you can use those procedures. Assuming you are talking about a manual transmission.
If automatic, then the only trans was a 01V. Same, find a procedure for the auto.
1 - 2 of 2 Posts
