Hey all...I ordered some Metalmaster front and rear pads a few months ago. Anyone know the correct part number for the pads with the sensors? Or what should I be looking for to make sure they came with the sensors?
Thanks
The Axxis Deluxe Plus pads I got for my 03 1.8t FWD had sensors on them. D-shaped connector attached to a pigtail attached to the pad. Can't miss it.
There's a trick to getting the pads off. The wire is routed through an area not large enough to get the connector through. Trick is to take off the bolt that holds the little bracket that's right there. You'll know what I'm talking about when you take the wheel off and look at it. It's pretty straightforward.
