1 - 18 of 18 Posts
I saw this on VWFIXX.COM and thought it might help people with some of the finer details they didnt know! Apparently my passat comes with 170BHP standard and a K03S Turbo! I'm happy if thats true according to my engine code AWM!!
1.8T Discussion Forum
Engine Code
AWD
Displacement
1.8L (1781cc)
Cylinders
4
Valves per cylinder
5
Bore diameter
81.0 mm (3.19 in.)
Stroke
86.4 mm (3.40 in.)
Compression Ratio
9.5:1
Fuel and ignition system
2000-early 2001
Motronic ME7.5, OBD II
Boost Level
0.6 bar / 8.7 psi
Turbo size
K03
Downpipe size
2.17" (55mm)
Horsepower
150 @ 5,700 rpm
Torque
155 ft-lb @ 1,750 rpm
Oil Capacity w/filter
4.6 qt. (4.35 liters)
Manual Transmission
02J
Models with this engine:
- 2000-early 2001 Jetta
- 2000-early 2001 Golf/GTi
Engine Code
AWW
Displacement
1.8L (1781cc)
Cylinders
4
Valves per cylinder
5
Bore diameter
81.0 mm (3.19 in.)
Stroke
86.4 mm (3.40 in.)
Compression Ratio
9.3:1
2001
Boost Level
0.6 bar / 8.7 psi
Turbo size
K03 w.K04 compressor
Downpipe size
1.97" (50mm)
Horsepower
150 @ 5,700 rpm
Torque
162 ft-lb @ 1,950 rpm
Manual Transmission
02J
*AWW engine code uses electronic engine performance control through the use of variable camshaft timing
- 2001 Jetta
- 2001 Golf/GTi
Engine Code
AWP
Displacement
1.8L (1781cc)
Cylinders
4
Valves per cylinder
5
Bore diameter
81.0 mm (3.19 in.)
Stroke
86.4 mm (3.40 in.)
Compression Ratio
9.5:1
2002-2003
Boost Level
0.8 bar / 11.6 psi
Turbo size
Downpipe size
1.97" (50mm)
Horsepower
180 @ 5,500 rpm
Torque
174 ft-lb @ 1,950 rpm
Manual Transmission
02J
*AWP engine code uses electronic engine performance control through the use of variable camshaft timing plus increased boost
- 2002-2004 Jetta
- 2002-2004 Golf/GTi
- 2002 Turbo S New Beetle
Engine Code
APH, AWV
Displacement
1.8L (1781cc)
Cylinders
4
Valves per cylinder
5
Bore diameter
81.0 mm (3.19 in.)
Stroke
86.4 mm (3.40 in.)
Compression Ratio
9.5:1
2002-2003
Boost Level
0.6 bar / 8.7 psi
Turbo size
K03
Downpipe size
1.97" (50mm)
Horsepower
150 @ 5,500 rpm
Torque
155 ft-lb @ 1,950 rpm
Manual Transmission
02J
- 1999-2000 New Beetle - APH engine code
- 2001-current New Beetle - AWV engine code
Engine Code
AEB, ATW, AUG
Displacement
1.8L (1781cc)
Cylinders
4
Valves per cylinder
5
Bore diameter
81.0 mm (3.19 in.)
Stroke
86.4 mm (3.40 in.)
Compression Ratio
9.5:1
1998-2001
Motronic ME7.1, OBD II
Boost Level
0.6 bar / 8.7 psi
Turbo size
K03
Downpipe size
1.97" (50mm)
Horsepower
150 @ 5,500 rpm
Torque
Manual Transmission
02J
- AEB - 1998-May 1999 - Passat
- ATW - May 1999-May 2001 - Passat
- AUG - May 2001-late 2001 - Passat
Engine Code
AWM
Displacement
1.8L (1781cc)
Cylinders
4
Valves per cylinder
5
Bore diameter
81.0 mm (3.19 in.)
Stroke
86.4 mm (3.40 in.)
Compression Ratio
9.3:1
2001-2003
Boost Level
0.6 bar / 8.7 psi
Turbo size
Downpipe size
1.97" (50mm)
Horsepower
170 @ 5,900 rpm
Torque
166 ft-lb @ 1,950 rpm
Manual Transmission
02J
Differences: Injector size, intake manifold volume, variable cam timing, hybrid K03/K04 turbo, different cat outlet diameter and overall length, plus other misc. "improvements" to keep the 1.8Ts output from encroaching on that of the V6.
- 2001.5-current Passat
1.8T FAQ, frequently used part numbers (courtesy of Andy @ Ross-Tech)
-----Engine-----
Intake Air Filter
1JO 129 620 A (Fram replacement - CA8602)
Mass AirFlow sensor (MAF)
06A 906 461 A (for 2.0, but seems to work with AWD)
06A 906 461 D (AWD/AWW)
06A 906 461 L (AWP)
Transverse KO4 Turbocharger (upgrade for KO3'ers, not the TT225 part)
K04-9500001 (KO4 turbo actually the KKK part number, not VW's)
AWW KO3 Turbocharger
06A 145 704 S
Transverse Turbo Swap Parts
1J0 253 115 A (Turbo-DP Gasket)
N 907 678 01 Studs (x4)
058 145 791 Washers (x4)
N 013 812 8 Washers (x2)
058 145 757 B Gasket
06A 253 039 E Gasket
N75 Wastegate Regulator Valve
058 906 283 C (AWD/AWW?)
058 906 283 F (AWW/AWP/NB Turbo S)
Diverter Valve
06A 145 710 H (Old)
06A 145 710 N (TT/NB Turbo S)
N249 (Diverter Valve Selenoid)
028 906 283N (NB Turbo S/???)
Audi RS4 Drivers Side Intercooler
078 145 805J
Manifold Absolute Pressure sensor (MAP)
038 906 051
4.0 bar Fuel pressure Regulator
078 133 534 C
Injector Seal O-rings
06A 906 149 (set of 4)
Manifold insert bung
068 133 555 C
Fuel Injectors
06A 906 031 S (AWD, 317.46cc/[email protected], 369cc/[email protected])
06A 906 031 AB (APH, 281.78cc/[email protected])
??? ??? ??? ?? (AMB, [email protected], [email protected])
Intake Manifold Gasket
058 129 717 D
Positive Crankcase Ventilation (PCV) Valve
035 103 245 A
Head Bolts
06A 103 385 A (AWD, APH)
Stock spark plugs
NGK PFR6Q (Bosch F7LTCR, Autolite 9323)
Coilpacks
06B 905 115H (AWP)
06B 905 115G (AWW)
Oil Filter
06A 115 561 B
AWD 5-speed ECU
06A 906 032 CL
AWD Automatic ECU
06A 906 032 CM
AWW 5-speed ECU
06A 906 032 DL
AWW Automatic ECU
06A 906 032 DM
-or-
06A 906 032 GH
AWP 5-speed ECU
06A 906 032 HS
AWP Automatic ECU
06A 906 032 HF
AWP New Beetle Turbo S ECU
1C0 906 032
Lower Pendulum "Dogbone" Mounting Bolts
N 102 683 02 (8x45mm) - you need 2
N 102 466 03 (10x30mm)
N 905 970 03 (10x70mm)
Exhaust Manifold Gasket
058 253 039 G
Stock AWD Downpipe/Cat
1J2 253 058 RX
-or-
1J2 253 058 JX
Front O2 Sensor
06A 906 262 AG (AWD)
06A 905 849 E (New Beetle APH)
Rear O2 sensor (AWD)
06A 906 262 AJ
-----Transmission-----
TT180 Factory Short Shifter
8N0 711 051 (fits AWD/AWW)
8N0 711 051 A (fits AWP)
VW "High-Performance" 75W/90 Transmission Fluid
G 005 100 A1
2nd gear grind fix ... parts off "moclov"'s invoice (O2J Transmission):
[2] - G-005-100-A1 - oil, .5 litr
[1] - 00076 - brake klee
[1] - 02J-311-239-J - synchr hub
[2] - 02J-311-247-C - synchr ring
[1] - 02J-311-261-K - 2nd gear
[1] - AMV-188-200-03 - seal comp
[3] - G-005-100-A1 - oil, .5 litr
2nd gear grind fix ... parts off "genxguy"'s invoice (O2M Transmission):
[1] - 02J-311-251-J 1st gear
[1] - 02J-311-261-L 2nd gear
[1] - 02J-311-239-J synchr hub
[2] - 02J-311-247-C synchr rng
[2] - 02J-311-277-A synch ring
[2] - 02J-311-279 Outer ring
[1] - 02A-311-531-K reversgear
[2] - G-005-000 Oil-1 litr
-----Brakes-----
25Y GTI (256mm) rear brake Caliper carriers right: 1J0 615 425 E
25Y GTI (256mm) rear brake Caliper carriers left: 1J0 615 426 E
25Y GTI (256mm) rear brake splash guard shield left: 1J0 615 609
25Y GTI (256mm) rear brake splash guard shield right: 1J0 615 610
Audi TT (256mm) Rotors: 8L0 615 601
Audi TT Caliper left: 8N0 615 423 C
Audi TT Caliper Right: 8No 615 424 C
256mm OEM pads: 4B0 698 451
Wheel hub with bearing: 1J0 501 477 A
-----Body/Interior-----
Touch-up Paint
LST OM2 A7W (Reflex Silver)
LST OP2 Z5N (Nogaro Blue)
Euro 25th Anniversary Smoked Headlights:
1J1-941-017N (Passenger's side)
1J1-941-018N (Driver's side)
Laminated Glass Windshield for GTI/Golf (Jetta?)
1J0 845 011 L
1J0 845 011 M (with tinted band at top)
337 chin spoiler
1J0 805 903 L 007
Rear Valances
1J5 807 521 C (Jetta 4-Motion, Euro)
1J5 807 521 D (2002.5 Jetta, 4-Motion-style)
1J6 807 521 D (GTI 337)
1J6 807 521 C (GTI VR6 4-Motion, new US 24v GTI?)
Golf R32 Body Kit
1J0 807 217H GRU (Front Bumper)
1J6 807 421J GRU (Rear Bumper)
1J0 853 859B GRU (Side Skirt - Left?)
1J0 853 860B GRU (Side Skirt - Right?)
Window Regulator Repair Kit (old-style plastic)
ZVW 269 202 (Driver's side)
ZVW 269 201 (Passenger's side)
Window Regulator Repair Kit (new-style metal)
1JM898461 (Driver's side)
1JM898462 (Passenger's side)
EuroSwitch
1C0 941 531 A 20H
Radio Delete Panel (DIN panel that matches VW dash material)
1J0 857 231 1QA
Mk4 'Cubby hole'
1J0 857 058 B
©Copyright 2002 dubtuning.com. All Rights Reserved
PassatWorld Staff
To whoever moved this to Info Forum:
Lots of Golf/Jetta Info, prefer to have it deleted and let Info be Passat-only.
Some descrepancies with Bentley? Let's discuss this thread.
Engine Code
AWM...
2001-2003
my Bentley says Motronic 7.5
Boost Level
0.6 bar / 8.7 psi
I thought this was 0.7 bar for the AWM (vs. 0.5 bar for the AEB, ATW, AUG)
Turbo size
BW part no.: 5303 988 0029 (AKA: K03-0029)
OEM part no.: 058145703J
Can anyone actually substantiate the "K03 w.K04 compressor" statement?
Downpipe size
1.97" (50mm)
Are you sure? IIRC it is slightly larger...
3.9 Liters / 4.1 quarts
"including filter": 4.1 liters / 4.3 quarts
Manual Transmission
02J
5-speed "012/01W"
codes for manual trans paired w/ 1.8T engine vary by model year: DHW, DHY, DVX, EHV, EZG (not sure which apply to the AWM).
Differences compared to what?
Seems like there is a lot of questionable information in the original post...
I'm not even convinced the "K03-Sport" is an *actual* part with a specific Borg-Warner part number. It seems to be a catch-all to describe several different K03 turbos: K03-0025, K03-0029, and maybe even more.
I think they are referring to the differences to a 150 hp motor vs a 170 hp motor, ie. where did the extra 20 hp come from?
my car has an awm motor and a ggh code 5 speed manual i dont know why they used a weird tranny instead of using the one from the a4. it is 4 motion.
I wondered about the validity of that original post too. The red flag for me was the supposed .6 bar boost spec. I have a stock engine (other than intake and hybrid diverter) and I will spike up to 12.5-13psi and will hold 10.5-11.5psi. I have checked my engine and it is an AWM. 2003 with a manual trans.
okay on the answer to the vvt thing. is the head or something else designed differently? anoter thing is the a4 geared taller or shorter than the passat?
The final drive is the ring and pinion. It is inside the transmission (at least for the front wheels - may be at the rear axle for the rears, but may not... I never worked on mine to that level). The transmission is the 'same' as the others, but has a different part number because there is different final drive gearing inside it, and it has the tailshaft output for the rear.
AFAIK the differentials are the same.
1 - 18 of 18 Posts
