I've got a question, so I need to check/change the ATF oil in the automatic transmission (not Tiptronic). How can I do that? :???: My car is a '98 1,9 TDI 110HP Variant.
OIL STICK
The automatic transmission version usually have a stick for checking the fluid level, but maybe you have to read the service book??
pallas :???:
I suspect it is a lifetime closed system setup. Only way to check it/change it would be with a VAGCOM like it's Tiptronic cousin.
My aut. transmission has no stick but I found the way to change the fluid. (The old fluid was very dark and smelly, so it was the time to that. Now the transmission change the level a little bit sooner.) :thumbup:
THX :bow:
