can i put eibachs audi A4 1.8T fwd(frontrack) sportline kit on my 2001B5 , caus i can get a kit from my buddy??should i?? :???:
i've been trying to figure this out for a long time and i cant get a straight answer from anyone. it makes sense to me that they should being the same motor and chassis, the only thing i can suggest is have your car corner weighted and try and find out the corner weight of an a4 and compare also the gvwr of both cars. good luck
p.s: i have two sets of eibach pro kit springs for sale for an a6 front trak. CHEAP!!!!!
NO.
Front springs will work, rear springs are way different.
Passat uses a separate spring and shock setup in the rear (a la MKIV VW).
Audi A4 FWD uses a coilover spring shock setup, similar to the MKII/III VW's.
Won't work.
