Re: ATP Just Released Their Stage II Turbo 250-280 [email protected] $1950 (NUISANCE)
Someone please correct me if I am wrong, but it appears that this kit uses the stock exhaust manifold (which I hate). Also, I don't see that the fueling issues on the older 1.8t motors will be addressed by this kit, i.e., no upgraded injectors, just a "High Rate Fuel Pressure Regulator".
Don't get me wrong, this looks like alot of good stuff for the price, but I'm still holding my breath for a kit that comes in between a simple chip and the APR stage III that also properly addreses the exhaust manifold and fueling issues on my car.
Juan, where are you?
I've pasted the info from the site below for convenience.
<BLOCKQUOTE>quote:<HR>Stage II 250-280HP - $1950.00
TBO Garrett/Honeywell GT25/T28 Turbocharger
TBO Dual Ball Bearing Trim
WGT Internal Wastegate Actuator
WGT Internal Wastegate Bracket
MISC Exhaust Manifold Adapter Plate
DNP Exhaust Dishcharge Flange
MISC CNC Inlet Adapter - 44mm outer diameter
MISC CNC Outlet Adapter - 50mm outer diameter
HARDW 2 Water Banjo Fittings (14mm)
HARDW 2 Water Hoses (18")
OIL Oil Feed Fitting Adapter
OIL Oil Feed Line (48")
FUL High Rate Fuel Pressure Regulator
EP-MK418T EPROM, MK4, 18T Stage II
HARDW
* 8mm Studs(10) , 8mm nuts (10)
* 8mmà6mm Studs (2), 8mmà6mm nuts (2)
* 8mm hex bolts (5)
* 6mm bolts (3)
* 10mm bolts (3)
* Washers (20)
* KO3 TurboàManifold Gasket
* T25 Gasket
* Oil Return Gasket
<HR></BLOCKQUOTE>
