I am in the process of refreshing a 2003 wagon with a non 4-mo AT. It has 140k miles and the ATF is black, leading me to suspect it has never been changed.
I have changed ATF on Passats many times, so I know proper procedure. What I am wanting input on is the steps people think I should follow due to the extreme nature of this change.
How many times should I expect to change the fluid in order to get all clean fluid throughout the system?
Should I drive it at all between changes or just keep draining-filling-draining-filling until fluid is clean?
If draining-filling-draining-filling, should I wait and change the filter at the end or after the first drain? If after the first drain, should I change it again after the fluid is clean?
I am just nervous about doing this given that these trannies are famous for crapping-out.
Thanks everyone.
Thanks everyone.
