1 - 11 of 11 Posts
okay earlier this mounth i got a CEL emissions work shop
that would show up and then go away
over about the course of a week
its been out for a solid 2-3 weels
FINALLY i got my obd-2 reader and i got the code that was stored ( yes there was no cel and yes there was a code stored ( the dealer and shop didnt seem to belive me when i said they are stored)
anyway i got a P0118 = Engine coolant Tempeature Circut , HIGH INPUT
is there anyway that that could be related to my emission workshop CEL
either way what should i be doing
i was thinking of replacing the sensor but ill wait till i hear back from the great wisdome of the forum
I would say replace the coolant sensor. The coolant temperature is related to emissions (rich / lean I think it is). I got the same error on mine, replaced it and no more errors. Cheap fix for a little satisfaction. :D
Replace the sensor,check your vacuum hoses.
You shouldn't have to empty the system. It's right on the top of the engine. I beleive it's green or blue or maybe black. Yup, I think those are the colors.
the haynes manual said you would have to drain some of the coolant
since im going to be doing that
should i just flush the entire system while im at it
If you want to go that extra mile, sure. Can't hurt. But make sure you put back in the Stealership pink stuff for long life. :D
Discussion Starter #8
i saw pink stuff at walmart for 6 bucks ( it says for GM new coolant ( good for 5 years or 105,k miles
can i use that
do you dilute it with water?
Don't think so. VW has it "specially formuted" for the block and head. Don't know for certain though. I think it's LLC(Long Life Coolant) mainly. Anyone else know?
It's known as G12 coolant. It is NOT GM long life antifreeze or basically any stuff you can get in any 'regular' stores. You can get it places like www.ecstuning.com, I believe, for between about $13-20 a gallon, I can't remember what I paid. and also, you only put in a half of a quart of coolant for every quart of capacity you have in your car.
1 - 11 of 11 Posts
