So I decided to use my own car to travel for work this week. 250 miles from my house near Pittsburgh to Bethesda, MD. I met up with a friend near Bethesda for dinner and when I got in the car to leave, I knew something was wrong the second I turned the key. I noticed the letters for PRND4321 were all in little boxes and kind of ran together. By the way, 2003 Pasatt GLS with 1.8T and Tip - sorry about that - should have mentioned that first.
I had seen the car do this when you change it from program 1 to program 2 with the APR programming. I had it done last Summer and haven't had an issue before. The car then wouldn't start. I tried a bunch of times. Then, on a whim, I decided to enter my PIN code and put the car back in program 1 (stock) mode. It started fine. I figured, let's try and put it back in program 2 (93 octane) mode. I went through the regular programming steps; entered my PIN, held down set until the check engine light was flashing twice and released the set button. I got the normal alternate blinking of the CEL and the EPC lights telling me that the code was accepted.
Then I held down the res button to enable the lock out. The CEL and EPC acknowledge the code but wouldn't stop flashing. I was able to get the car started but it was like it had no power. I backed in to a different space and ran through all these steps again and was able to get the car running, but the CEL and EPC lights just kept on flashing. I decided to drive to the hotel in Bethesda from Germantown where I was and after about 5 minutes the CEL and EPC lights went out.
I made it to the parking garage and decided to temp fate one last time. No matter what I did it will not take program 2 anymore. I can get everything working fine in program 1 (stock) mode though, but program 2 (93) seems to be gone.
I am fine with stock mode as long as the car is reliable, but I'll miss 93 mode. Much better program in my opinion.
I figure I can go back to where I got it programmed a year ago and they can check it out, but I wondered if anyone else had ever seen anything like this before. It was a sickening feeling when it wouldn't start and I was 250 miles from home. Panic was going to set in soon.
I started the car a few times in the hotel's parking garage and it is fine for now in stock mode. So here I sit in the hotel in Bethesda hoping that everything stays OK.
Thanks for anyone's help.
