I recently went to drive my Passat and noticed the speedometer needle was sitting at 5mph and the temp gauge indicated 200 degrees.
I think in all the five years I have owned the car I have never seen the gauge above 190 degrees. My understanding of the gauge is that it won't actually move off of 190 degrees until the coolant reaches 210 degrees. Since the fans come on at 205 degrees they should have been running. Initially I thought of a stuck thermostat but the fans would have turned on in that case. I tested the fans by engaging the AC and they were working. After sitting for a bit longer (with the AC off) the fans did come on by themselves as they normally do and then turned off.
So my next thought would be the coolant sensor that seems to go bad in the AEBs quite often. But the speedo needle has me thinking it is a cluster problem.
Since the last time I drove the car the cluster has not been apart at all. The last time I took it apart was about six months ago and the needles were all set to the correct positions.
I'm going to try checking the actual coolant temperature with my VAGCOM this weekend. Driving the car had no affect on the coolant needle position. Who knows maybe the thing will fix itself since it broke all by itself.
.jpg)
