The throttle on my 1.8T seems to be connected to the engine via a very long rubber band. Stab the throttle......pause........then the revs start to come up. I'm not talking about acceleration here, the car is plenty fast. Nor is it turbo lag I'm experiencing. This is under a "free" revving situation. Basically, I like to heal and toe downshift but when you give the throttle a stab nothing happens unless you hold it down for a moment. I can retrain my foot for the timing necessary, but I wonder if there is a fix. There must be a 500lb. flywheel in there! I've also noticed that the revs continue to climb for a substantial moment after the throttle is closed, so maybe it's a cable routing or engine management issue.
the relative position of brake and throttle is poor in this car for heal & toe, but that can likely be fixed.
