1 - 7 of 7 Posts
Hey Guys,
My Enfig antenna broke off at the bottom threaded part. The threaded part is inside the base. Is there some way to remove it? If not, how can I remove the base to install another?
Thx.
4th Gear (Wax on Wax off)
If you can find a tiny EZ Out you could drill it and run it out that way .. I think the base replacement is a pain from what I have heard.
In a moment of stupidity, I tied a sheet a sheet rock to the top of my car. It wasn't secured as well as I thought so when I started driving, it slid back and broke the antenna.
This reminds me of all the stories of people's wheel locks getting stripped.
I wonder if you could crazy glue something onto the threaded part that is stuck in the base, let it dry, and unscrew it out. But now that I think about it, there probably isn't a glue strong enough to do the job. It would probably all depend on how tight your antenna was originally screwed on.
Part is cheap , about £15 uk pounds provided its not got a GSM telephone or nav requirement. If you don't get a good connection FM reception will be terrible as the signal booster is in the base after this connection.
1 - 7 of 7 Posts
