So this is the first time I've owned a car that needed a specific coolant and I don't have any problems with that... our local autoshop carries pentosin pentofrost SF which I assume is correct since ecstuning carries the same stuff and lists it as g12 compliant and safe for our cars... (2002 passat v6)
Now... it says on the bottle that it is concentrated and needs to be mixed 50:50 with water. One 1.5 litre bottle than makes 3 litres of coolant when mixed with water....
What do you guys do if you only need a top up and not flushing the system?
Is it safe to mix everything together in an empty window washer bottle and keep it on the shelf for the odd time you need to top up?
