1 - 3 of 3 Posts
Ok this has been a problem and i haven't found a good answer here on the site.
I have a 99 passat 1.8t and i finaly got my sub and amp but i have no ideea where i can feed that darn amp wire. Can some one help with a concise answer. I have searched for hours now here cause i know not to post with out serching and still no answer. Sone please tell me where trough the firewall can i run a 0 gauge wire to my amp.
Thanks guys!
you can go through the hood latch wire. thats where i went through..
if its manual you can go through the clutch up through the ecu.
there's also a triangular grommet next to the brake booster, another grommet you can get to if you take the battery out that's just under the master cylinder, you can go through the A/C line boot, the master cylinder boot, or like I did, the ECU housing.
1 - 3 of 3 Posts
