I believe my abs speed sensor (at least one of them) is bad because I have all the lights on the dash that go along with the described problem from other people. But what about the airbag light? Also my AFS don’t work and the cruise control won’t set. Anybody had this problem? 2013 vw cc with 80k
I had a similar issue on mine, once the hub was replaced ( it was the hub that was broken not the sensor in my case) everything went back to normal...
The hub or the bearings? Not sure if there is a difference. Some say the bearings were bad on theirs. Thanks for replying btw
