I am getting an "airbag fault" warning on the LCD and the airbag light stays on.
I just reinstalled the cluster after replacing the LCD, and while I was running output tests to re-calibrate the needles, the green connector came off momentarily while the cluster was powered. I suspect that may have had something to do with the airbag MIL and warning message.
I did a full scan and it showed this ABS code:
Control Module Part Number: 8E0 614 111 AH
Component and/or Version: ABS/ASR 5.3 FRONT D10
Software Coding: 00022
Work Shop Code: WSC 00028
1 Fault Found:
01203 - Electrical Connection between ABS and Instrument Cluster
31-10 - Open or Short to Ground - Intermittent
I cleared it and it didn't come back after driving around a few blocks.
When I do a full scan it doesn't show any airbag codes.
I am not sure how to go about clearing the airbag warning with vag-com (I have an older version). Do I need to run some output test or adaptation on a controller? Which one? Can someone walk me through the steps?
The car is a 2000 sedan, manual.
Here is the full scan which shows all the controllers on this car:
I am not sure when the P1113 came on. I'll clear that too and see if it comes back.
VAG-COM Version: Release 311.2-N
Chassis Type: 3B
Scan: 01,03,17,19,46
Address 01 -------------------------------------------------------
Controller: 4B0 906 018 BG
Component: 1.8L R4/5VT G 0006
Coding: 07501
Shop #: WSC 00028
1 Fault Found:
17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 17 -------------------------------------------------------
Controller: 3B0 920 920 B
Component: B5-KOMBIINSTR. VDO V26
Coding: 07245
Shop #: WSC 00000
No fault code found.
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00004
Shop #: WSC 00028
Address 46 -------------------------------------------------------
Controller: 1J0 959 799 AJ
Component: 6W Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 00028
End -------------------------------------------------------
1 Fault Found:
Chassis Type: 3B
Coding: 07501
Shop #: WSC 00028
1 Fault Found:
Coding: 07245
Shop #: WSC 00000
Coding: 00004
Shop #: WSC 00028
Coding: 04096
Shop #: WSC 00028
