I installed the Innovative Motorsports MTX-L wideband air/fuel ratio gauge about two years ago.
MTX-L Wideband O2 Digital Air/fuel Ratio Gauge
It's been great up till a little while ago. Then I started getting error 08 which is usually a bad O2 sensor. I got a new sensor but not wanting to cook the new sensor, I also got the heat-sink bung extender.
Innovate Motor Sports On-Line Store
The problem is, the bung I've got this installed in is the tall one.
The combination of the tall bung and the heat-sink extender leave the sensor pulled too far out of the exhaust stream to take accurate or responsive readings.
In your mind, imagine another inch of bung coming off the threads of the extender and you'll see it doesn't penetrate into the exhaust flow enough.
So I need to remove the sink/extender but I still want some thermal protection if I can to keep from cooking expensive sensors.
I made up a solution I hope will work.
I have thick copper plate to act as a heat sink. This goes between the sensor and the bung like a crush washer but with a bigger outer diameter. Hopefully this will dissipate some of the heat conducting from the bung to the sensor. Copper conducts heat very well.
In addition to this I have a stainless steel plate suspended below the copper heat sink to act as a heat shield. The shield is to protect the sensor from heat radiating off the exhaust pipe. Stainless steel conducts heat poorly.
Here it is installed way down behind everything trying to get in my way of taking a good picture.
The reason for the cut-out in the heat shield is because my #2 sensor is right there and I needed to afford it some clearance.
A test drive showed the gauge readings were back to normal so the sensor is now in the exhaust deep enough to take readings. As far as knowing if this modification will make my sensor last any longer, I guess I'll know in two years.
