1 - 7 of 7 Posts
ok, i just got my JVC headunit installed, so now i want to install my subs
ok.. i have no idea how they put the new radio in... but how do i take it out ?? or at least reach the back of it so i can hook up the cables
its a 98 passat B5
i am not sure how jvc units are installed, but you need to pull it out. aftermarket units use mounting brackets, and i think some of them have these keys that go into the side of them so you can pull out the unit easily. look at the installation instructions that came with the unit.
you have to take of the faceplate trim .....if you have the installation keys you slide it in and pull it out .....if you were in NYC i would do it for ya cause i have a set of JVC keys for that ....
what they said above x2. and in addition, you gave us about 5 1/2 hrs to answer you - bad form! be patient, as we aren't all at your beck and call 24/7/52!
1 - 7 of 7 Posts
