1 - 20 of 23 Posts
I have search around and found a few threads about aftermarket head units that look oem (with matching red/blue lights). However, there is really a dearth of good pictures, and I haven't been able to find any comparisons that are very comprehensive at all.
So, if you have an aftermarket head unit in your car, it would be great to hear a little bit about how it looks in your car, how well the black matches, how well the red/blue lights match, etc. It would even be better to compile a good set of photos in this thread with pictures taken at night and in the day.
If you are interested in contributing to the cause, post away!
I just put in a kenwood DDX-6017. Looks VERY OEM. red buttons match, and the blue SRC button matches the blue dash VERY well!
The only problem is the 6017 has a silver frame. I actually messed up when bidding on ebay, I meant to buy the 6019. Black frame, same buttons. Looks very very OEM.
In addition, i put in: 10" alpine type R (in an Stl5B box), 600W alpine amp, HD Radio tuner, TV tuner, and an aux. jack. (for iPod, scanner, computer, whatever.) Didn't lose any trunk space, got all the wires hidden, nothing shows, except for a litle bit of the TV antenna at the bottom of the back window. All in all, I'm extremely pleased! All I have to do is adjust some SQ, but that will come with time.
PS how do you post picture in a thread...is it not possible in the "quick reply" box? (which is where i'm typing now...)
you have to host it on a site like photobucket.
single or double din?
Double din Kenwood DPX-701:
Hey man:
Where did you get, or how did you make the trim ring that you have going around your double din radio in this picture?? I have a double din nav unit that I'm going to be installing and I'm pretty sure I'm going to need a trim ring to make the install look proper. Hell, come to think of it, did your radio include a radio sleeve for install or did you have to fab some mounts to make it secure??
Well I could get a double din sleeve on ebay for next to nothing. But you were saying something about needing to fab mounts because even with sleeve there wouldn't be anything to lock the tabs to. Is that the case? If I put the radio in the opening is there nothing back there to hold it up, or does it just fall into the hole?
My intake has Emphysema
Paul is right. It came with the trim ring, I also have a extra DD sleeve from my previous Kenwood DD unit and the trim ring as well. It's not as wide as the current one though.
You'd be able to lock the sleeve in but there wouldn't be any way to lock the radio into the sleeve.
1 - 20 of 23 Posts
