1 - 11 of 11 Posts
coilovers installed, need to get new upper control arms to fix the negative camber. will raise it back up a little when they are put on. here are some pics
STOCK
WHEELS
COILOVERS
julianfang said:
:thumbup: :thumbup: :thumbup: :thumbup:
starting the right way bro!
pretty excited. having to get the control arms probably delays the body kit a couple of more months but I am pretty happy with the way it looks as is so its not a real priority.
chip and exhaust next year!
Bleser said:
Looks fantastic! What control arms are you referring to, by the way?
upper control arms. ordered a set of the CPP adjustable arms as the drop caused the alignment to go out of whack. The camber of the front wheels is coming in at a little over 2 degrees which is, from what I understand, outside the acceptable limit and will cause the tires to wear unevenly. the b5.5's don't have anyway to adjust this with the stock arms so I needed to get the CPPs.
BTW, Thanks!
1 - 11 of 11 Posts
