I tried searching but can't find anything substantial. Anyone know where I can get the pcv crankcase pipe/tube set? Thanks!
You don't have all of that on the AEB engine. For the PCV, you will need at least this:
https://www.ecstuning.com/b-assembled-by-ecs-parts/breather-hose-service-kit/058198298/
Along with this:
https://www.ecstuning.com/b-hamburg-tech-parts/pressure-control-valve-pcv-19mm/035103245a~ham/
If you have a Tip trans, you will probably need this too:
https://www.ecstuning.com/b-034motorsport-parts/silicone-breather-hose/034-101-3024~034/
Anything else, you can usually use vacuum hose. The check valves (I think the AEB has 1-2), you can get here:
https://www.usplastic.com/catalog/item.aspx?itemid=23369&clickid=redirect
Reactions: hodgson316
