use a nail punch to make in indentation on the trunk and then use a small bit first to make the initial hole and work your way up to the appropriate size drill bit.
and blow the shavings off - do not sweep them off
If your going to put the spoiler at the edge of the trunk, instead of where the pattern suggests...you might want to tie a string to the bolts before trying to put them in from way inside the trunk. I dropped one in there and I never could get it out. So I hear it every time I open and close the trunk now. :D
