I've had some trouble adjusting my kw v1's, the rings in the front are completely siezed to the point where they metals adjustment hooks were starting to bend, and that's with pbBlaster being sprayed on for awhile. Has anyone else had this problem? I'm thinkin about taking it to get adjusted somewhere cause this is out of my league at this point. Does anyone know who will do this, or do i have to find some sort of speed shop?
EnjoyTheView said:
I've had some trouble adjusting my kw v1's, the rings in the front are completely siezed to the point where they metals adjustment hooks were starting to bend...
I've got the V2's but I assume they're the same in front.
You're aware that there are two rings correct? You have to loosen the bottom ring first to move the top ring.
Just checking. I forgot to do it once and thought they were seized - until I remembered.
