1 - 1 of 1 Posts
Hi, I was given a 2007 Passat 2.0T and the air con is not working. Here is what I know already -
The system has been vacuumed down and recharged correctly with zero leaks
The gauges show that the compressor is not compressing with no build up of pressure on the high side and a pressure drop on the low side
I have tested the pressure switch by the right headlamp and have battery voltage, earth and a signal approximately 4.5 volts
I have tested the connection to the compressor solenoid and have an earth and a signal reading approximately 4 volts
The fans do not kick on with the AC and only with engine temperature rising
All the controls in the dash 'appear' to work
If I apply battery voltage to the compressor solenoid I hear a 'click' coming from the solenoid but not sure if 4 volts is correct.
Any help to prevent me wasting money on an incorrect diagnosis would be really helpful.
1 - 1 of 1 Posts
