So I just turned a sharp left corner and both the ABS and BRAKE lights flashed, along with a beep. I'm traveling for work and don't have access to a VAG-COM or tools, or time to look it over right now. Does anyone have any ideas? I was thinking low on brake fluid maybe, since it happened in a turn. Brake wear sensors? The lights and beep lasted 5 seconds and then went away, if that helps.
Oh yeah, '99 1.8T Tip. Thought that'd be useful. :D
HELP!!!
Hopefully, your just low on fluid. I had the same problem and it turned on and off, and now its permanenetly on. I would suggest you look at your fluid levels and sensors on the wheels if they come back on.
