1 - 14 of 14 Posts
I am not sure but i think i read sometime ago that mods where needed for A4 seats in a b5.5
I havent tried myself
I'm Urlik's Hero
I'm paraphrasing another member's post here;
Any interior from any A6/S6/RS6 WILL NOT FIT, apart from the front seats which happen to go straight in. The rear seat is about 4 inches wider, major modification required.
A4/S4/RS4, will not fit without major work, A4 & S4 rears fit with some work, fronts require fabrication/cutting. S4/RS4 recaros will fit with a change of mounting brackets to RS6 items.
How tough is it, is it similar to a s4 seat swap. Info, pics.
it depends on what seats you currently have...for instance, any power seats on the B5 Audis have a totally different mounting scenario than the non-power seats.
B5 Audi A4 sport seats are non-power, the B4 Audi S4 seats are powered so the two are non interchangable without some modification of the chassis.
anyway, this is how the seat interchangability is on the B5 Audis.
I'm Urlik's Hero
RS6 fronts go straight in, obviously the plugs are different. The rear bench is wider
1 - 14 of 14 Posts
