When I turn on the front fogs, the indicator on the euro switch goes from red to green indicating that they are on (same as the US switch). However, when I switch on the rear fog, the light remains red. Is this normal, should it also change to green or is there some additional wire that needs to be done?
Thanks for you help.
Depending on the euro switch, you may had to add an LED and resistor to the circuit board of the switch. Search around and you should find a write up on it.
Regards,
gordy
