a few engine codes, boost leak i suppose ? HOW DO I REMOVE THIS PART?
hey guys
i have a 03 passat GL 1.8T
it has the speedtuning flash in it and 93K on it
the folowing codes show up on the VAGcom
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 002 - Lower Limit Exceeded
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - Implausible Signal - Intermittent
16685 - Cylinder 1: Misfire Detected
P0301 - 008 - Implausible Signal - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 008 - Implausible Signal - Intermittent
16683 - Boost Pressure Regulation: Control Range Not Reached
P0299 - 002 - Lower Limit Exceeded - Intermittent - MIL ON
first of all, am i right to assume that the first codes is the reason for the other 4 ?
i checked the DV and it seems fine
(its a steel case bosch version with the stiffer spring and plate in it)
i should have a boost leak tester flaoting around somewhere in the garage, that would be the best place to start right ?
hey guys
