1 - 3 of 3 Posts
Lisa Simpson
So... I've been having this idle problem for next to ever. I've replaced every stupid check valve, vacuum hose, you name it.
Today, I popped on the A/C to clear some humidity out, and my idle dropped to where it belonged. What? I shut it off, and it quickly drifted right back up.
I pulled out the Bentley and went into the morass that they call schematics, and lo and behold, the A/C switch sends 12V through the ambient air temp sensor to something called the "A/C Diode". The A/C Diode feeds the idle boost controller in the cluster! No shit!
So... Where the hell is the A/C Diode located, so I can test it and see wtf is going on here?
2000 ATW Manual, manual climate control
If I am reading my manual the right way the diode is in the instrument panel wiring harness shortly before or after a connector with a black/yellow wire on one end and a black/red wire on the other end.
Can't tell if it's connector a64 or 30
I know this is an old post, but has anyone had any luck finding this? I think this may be what is causing my a/c problem and seeing how I live in FL I am dying to get this fixed!! PLEASE HELP!! :bowdown:
1 - 3 of 3 Posts
