1 - 10 of 10 Posts
The turn signals and emergency flashers on my '99 suddenly refuse to work. Both respective fuses look OK. Bad relay doesn't make sense, as I think it's two separate relays, and I doubt they'd go out at exactly the same moment.
Any suggestions ????
They run through your hazards... remove the center console and see if the hazards switch is in tight, or something is bad with it.
Well, I'm not so sure now-----they both started working again, after I jiggled the turn signal lever ! Strange.... :crazy:
Anybody wanna revise their opinions, or are you sticking with the relay ? No reply necessary if you're still sold on the relay........
Thanks for everybody's help.
I had the same thing happen to my '98 - It was the Comfort Control Module [CCM]. Shorted, causing the same thing you are having.
Also thought it was the relay. I happened to be at the dealership for an oil change, so they tried one from another car on the lot to see if it fixed the problem. Didn't, so the tech troubleshot it and found the problem was with the CCM.
im having mad electrical problems like brake lights goin out the light in my dash went out and now my tiptronic wont work and the letters in the odometer and now backlit i read the manual they say its and electrical prob i dont get the electonics
Where is the CCM located? My buddy is having serious electrical problems. Windows only go have down, exterior and interior lights work whenever they feel like it, etc.
1 - 10 of 10 Posts
