A little back story, I got this car as a project, is fun to drive, when its running :/
Everything was running fine, drove it over 1500 miles from WA state to SD with the only issues being in the suspension. I did notice it didnt seem to have as much power as it should going through the mountains almost as if turbo was lagging, but nothing major, other than sucking down gas like no other. I was getting maybe 120 miles to a full tank! Driving my Denali was cheaper.
i purchased the car from a guy who runs an Audi repair shop, and this car was bought for his guys to have something to work on to avoid lay off when covid hit. They claimed to have re done the coolant system, and replaced the ECU. As well as halfway gutted the interior (looking for a headliner btw if anyone has one laying around lol).
When i got to SD we had replaced the spark plugs and one ignition coil, as we were told it “misses every now and then” from this one coil as it needed to be replaced. I did this in hopes to improve my power issues. When doing the plugs, one of the spark plugs snapped in half when removing it. Was able to get it all out with handy dandy magnet, and replaced. I got BOSCH Immodium plugs. I also want to add the CEL is on, hut i cant get a connection when trying to pull the codes, just an error. I have tried multiple scanners.
Car sat for about a week without being started as there was lots of snow and below freezing temps. After about a week i was able to dig her outta the snow and start her up, couldnt get the heat to work for the life of me. I tried daily for about a week letting her warm up for 20-30 min drive around the block, no heat still, then park as its below 20 and very chilly. Finally decided to try and drive her a while to see if i can get things flowin and she did eventually “defrost”, heater would start working on and off and temp guage finally raised but would keep dropping. Then the heat would only work if going above 80mph, almost like it was because the engine was able to warm up to a certain point before the cold air cooled it back down. Im also missing the bottom half of my front bumper, exposing the radiator partially, so figured when on freeway the radiator may be getting too much of the ice cold air flowing thru it.
Anyways, then it started to overheat the next day, if i let her idle too long or go over 70mph but would quickly cool down at lower speeds. Never fully overheated though.
That same day i noticed a weird almost ticking sound coming from what sounded like the back seat. Not sure what it was or if its relevant but dont want to leave anything out.
The next day, i filled her up at the gas station and she didnt want to start when i went to leave. Took a good few minutes to get her to start.
Later that day i was heading to a friends about 60 miles away, and after about 5 min on the freeway, i heard a noise almost like a tick, and i had the heater on high. I reached and turned to heater off so i could hear the noise better, and the car completely dies on me! Try to pop the clutch, and cant get her to start. Pull off to the side of the freeway and take a look under the hood, everything seems to look fine nothing obviously broken or out of place. Try to start her up and the starter just spins making almost a whining noise.
Had AAA tow her to the nearest approved shop, they call today saying they thing the crank shaft broke, and that only the back 2 pistons are moving? And that my engine is toast, quoting over $6k to replace!
I really dont think this is the problem. Hoping someone may have had a similar scenario that can shed some light?
could it be the serpentine-belt tensioner pulley? I was told the water pump/timing belt was replaced when the prior owner had it in his shop but i cant say for certain.
Any advice is greatly appreciated!
