I bougt a 94 passat glx and the transmission slips but the more gas you give it the less it slips and most i have seen mess up more when you stomp it. Does anyone know if it might be the torque converter and how much should I be looking to spend on a used transmission.
Thanks John
This forum is for the B5/B5.5. This denotes the Passat 1998 and up. (The Passat received a complete overhaul in 1998, and only vaguely resembles it predecessor.)
www.vwvortex.com has a forum for pre-1998 Passat's, which will have more information for you.
SirWired
Lisa Simpson
Yes, we do focus on the B5 gen Passats.
I moved you over.
It sounds like your tranny has a valve problem in the automatic. It is an auto, right? If it's a stick, you need a new clutch. Give us a few more details - type of tranny, engine are most important.
Its a 94 vr6 automatic. Ive heard you can put a 5 speed out of a four cylinder jetta in it. You know if this is true or not
Thanks
