1 - 20 of 24 Posts
no not my passat:), our drag car running 2.0 20v and still bosch Me7.5 ECU made 715whp 528ft/lbs on mustang dyno(dynojet 750+whp) still using Eurodyne 1000cc file, simply wanted to let you guys know that wanted to run other software... no need we got you covered. we will be at show and go april 5 in NJ come say hi.
dip in powerband is the EBC that needs tuning wich we will do at the track.
This is on our New AX368 turbo from bullseye:thumbup:
Resident a-hole knowitall
very nice, got a video of the dyno pull :lol:
Discussion Starter · #6 ·
we want to run deep 9s this year, when not sure but car is pretty much the same so should go high 9s off the trailer on low boost.
we ran [email protected] with [email protected] last year
we now make [email protected] and weigh 100+lbs less and have a Dogbox and wheelie bars so with that and a dialed in rear suspension i think we can run 9.7x9.89 range once we get the car going that fast with that boost will crank it to 37-38psi and see what it does
see you then
need videos of the runs when you get to NJ :bowdown:
1 - 20 of 24 Posts
