Coming up on my 60K on my 2003...and the end of my warranty... scary
uke:
Here is the list of scheculed maintenance for my 1.8T Manual. Seems like a whole lot of nothing for what they will charge.
I bolded the stuff that I will have the dealer do (I usually change my own oil but want to make sure they do it before the 60K).
What I really want is a good check up on my engine and drivetrain to make sure it is in good working condition. What to do?...
Engine Oil - change
Engine Filter - change
Windshield Washer Fluid - check level
Brake System - check damage/leaks, pad thickness, fluid level
Wheels - rotate from front to rear
Air Bag System - check function/damage
Battery - check electrolyte level
Engine - check for leaks
Front Axle - check dust seal on ball joints and tie rods; check tie rods
Pollen Filter - replace
Cooling System - check level
Transmission - check for leaks; check oil level
Tires/Spare - check condition
Driveshaft - check boots
On Board Diagnostics -check Diagnostic Trouble Code memory
Door Hinge - lube
Headlights - check and adjust if necessary
Exhaust System - check for damage and leaks
Sunroof Frame - clean and lubricate
Road Test-check system functions during and after
Engine Oil - change
Door Hinge - lube
