1 - 2 of 2 Posts
Hi,
I have a 2000 vw passat it has the VW 6 pack cd player in the rear. What my problem is it reads a error on every cd in will not play it.I notice it over the last couple months the odd time. When it play it was fine.. Now it will not play at all:cry: I have tried different cd's and also took the unit out to see if anything noticeable inside. I even blew it out with real low compressed air. thinking dust.
My question has anybody ran into this issue before?What did you do?
Should I take it to my VW dealer or take to radio repair place?
Thanks any info would be great!
I'm guessing that the light beam that reads the CDs is burnt out or misaligned. Check all the connections though, you might get lucky.
Not really somthing you can fix. Easiest way to check out whether it's the head unit or CD changer is to "borrow" and hook-up someone else's CD changer.
1 - 2 of 2 Posts
