1 - 2 of 2 Posts
I recently put some new led lights in the interior ( dome lights ) i only put the ones in the front because if i put 2 more in the back it kills the fuse... so can i put a 7.5 fuse or will that do damage to wires?
2010 PASSAT 2.0T
2009 Passat Wagon
2010 PASSAT 2.0T
I replied in your other post regarding the LED lights.
Are you thinking to upgrade your 5A fuses to 7.5A if i read correctly? If that's the case i would strongly caution you to not do that. Otherwise can you explain what you mean if this isn't the case?
Passat B6 Variant/Wagon 09
1 - 2 of 2 Posts
