As promised yesterday, I began the task of buttoning up the engine. Enjoy the progressive pictures:
All rockers have been adjusted and locked down ( hyd. roller are adjusted 3/4 turn after play is taken out of the pushrod ).
Intake manifold: all water passages silicone'd on both sides before it went into place. All bolts progressively torqued to 17, then 25 ft.-lbs.
Valve Covers on. Will need to remove later for verifying oil flow during initial oil pump priming.
Holley Street Avenger 670cfm bolted in.
OOOHHHH..... shiny!
MSD alum. billet distributor with STEEL gear; break-in lube applied to gear and a little on the O-ring; I believe I have the rotor pointed in the correct position, however, this will come out for the oil pump priming later on.
Took me 2-3 hours to complete it to this point.
OOOHHHH..... shiny!
