This is a new thread that continues on from this thread http://www.passatworld.com/forums/42-volkswagen-passat-b5-discussion/385105-should-i-get-these-things-fixed-college-kid-2.html
Front Tie Rods replaced
2 new front tires replaced
"New" used Axel with CV boot
Air intake was returned to stock
I did nothing about the right door wiring harness
I did nothing about the SAIP
I did nothing about the Armrest
And I don't think I'm going to do anything about the "carbon buildup"
After all this, my funds were cut in half. In the time since, I built my bank account back up to around $1300.
#1) Yesterday my head unit died, so I need to get a new system. The right side has been out since day one and now the whole thing just doesn't play. I'm an audiophile, I need music.
Today I went to the mechanic for some parts... I want to run bg44k through my tank and I read I should change the fuel filter first. My coolant was also low.
#2) I asked the dude how much a fuel filter would cost. $95 for parts and installation.
1.5 liters of G12 coolant was $15
Before I left, my sixth sense tingled. I asked him how I can check to see how much brake life I have left. I told him how much I have left on the fronts (1/2") and how much I have on the rear (1/4"). He said I should be good for now. I asked him if a sensor would let me know when I need to change them and he said yes.
I drive home and right as I pull onto my street... CHECK BRAKE PADS
#3) Quoted at $190 for pad replacement on the two front tires, and $325 for rotors and pads... for the front. Visually inspecting the rear ones tell me that those will need to be replaced soon too as they are down to 1/4".
I have an inspection coming up on June 23rd that I may not pass.
#4) Apparently my windows are tinted too dark (BS! they are lighter than what comes stock on most cars now-a-days). Apparently I need to have the tinting removed.
#5) My headlights are too dim (Again BS! They are brighter than my mother's Nissan Altima's stock "high intensity" headlights. If anything they are too bright...) Apparently I need to have them removed and install stock ones.
#6) Tail lights are tinted black. They need to be returned to stock. This one I understand and is agreeable.
#7) Engine Light still going off due to SAIP I believe
On top of all this, I have to change my oil.
I was accepted into Pitt, Penn State, Temple and Rutgers. I want to bring a car to college but don't necessarily need one. Especially if I go to Pittsburgh. I'm completely against selling my car though. Even having the expense of a car while not in use is still more appealing to me than sacrificing my freedom and selling my passat. I at least want to hold on to it until I go off to college.
That being said, I would be willing to buy a miata... I think
Help me please I need advice
Battery was replacedL&T called [mechanic]:
Here is the official list in order of importance in their opinion:
1) Battery is dead ($125)
2) Front tie rods have play in them. Parts, labor and alignment: ($275)
3) 2 new front tires (Unquoted)
4) Right-front CV Boot. Axel is not damaged yet. Parts and labor ($145)
5) Cold Air Intake. KN filter tubing is cracking. Return to stock. (Unquoted)
6) SAIP is iffy. Throwing codes but still working.
7) Right front door wire harness is bad. ($225)
8) Center armrest lid is broken (45)
--- and the biggie --
9) Intake manifold carbon build up. He said parts are expensive but the labor is. He didn't specify a price, told me that he didn't because he wasn't sure if I want to tackle it. I was notified of this problem in July, and I tried using sea foam. So major problem in foreseeable future.
What does do?
I have $1500 total cash right now, and I think when I do my tax return I will get it all back. I only made 4600 and they withheld 900.
