1 - 1 of 1 Posts
I have the above car. I have just under 80K miles on it. I drive a bunch, clearly. I've followed all of the maintenance schedules and then some, but have this re-occurring issue with acceleration. Occasionally, out of the blue, the car has a big lag in shift from gear to gear, most prevalent in the lower gears. I've found that it happens after maybe a minimum of 20 mins or so of highway driving at 55+ and then when I get off the highway at the traffic signal, the light turns green and my acceleration problem hits. I'll get to where I need to be and turn off the car. But then when I start up again, poof the problem is gone. What gives? Issue began around 35-40K miles Here are some service notes: No lights to indicate an issue Brake fluid flush at 30, 60K Spark plugs changed at 50K due to high miles driven Transmission flush at 40, 80K All other regular maintenance intervals met
Any insight is great!! Thanks!
1 - 1 of 1 Posts
