1 - 3 of 3 Posts
Sorry if this is an obvious or over-asked question but; Does a 2017 1.8T Passat have a belt or chain?
When should it be changed?
If it's a chain, do I just have the tensioner and whatever else services or does a chain need replacing as frequently as a belt?
Also, while adding windshield washer fluid the other day, I heard a ticking sound. Reminded me of a "lifter" or valve sound.
I read somewhere that it's either (1) Normal at idle, (2) some sort of tensioner, or (3) normal fuel injector sound......
Since this car has been so reliable (32k - 62k since I got it late last Nov. (2018) do much to it and I don't know if it's always been there or if it's new...
I change the synthetic oil every 5k although it could go longer between between changes......I'm from the "every three thousand miles" generation...
I've had a Suburu nearly broken in at 265k before I sold it off and the guy is still driving it around the city two years later.....
I've had two Volvo 240 Wagons go past 200k .......
I want this to last so I don't want to blow up an interrupt engine and it's not easy finding definitive info on the internets...
Anyone?
Anyone?
Mine has only 55,000m so not ready, but Salesman told it has a belt drive at purchase. Maybe he should talk to his mechanic.
1 - 3 of 3 Posts
