Hey guys my Volkswagen seems to be in limp mode but I can go through all gears the problem is that I can’t get over 115 when when I first got it I was going 150 the only code it’s throwing was my o2 sensor because I’m Cat less I’m having trouble figuring out the problem I have taken it to vw they didn’t see anything wrong with it so i think the waste gate is either stuck open or closed bc I can hear it spool very loudly and says I’m building 14 psi at idle at about 800-1000 rpms and when slowly revd it only builds 1 pound is there anything I should look at before pulling it apart and checking the turbo?
