1 - 8 of 8 Posts
New to this site, but having an issue that I really need help with
My Passat has 88K miles. The symptom is that when cold, the engine idles a little high for about a minute, as designed, then goes to normal idle for a minute or two, then starts to surge for a few minutes, or until the engine temperature reaches about 1/2 way to normal full temperature. After that, the engine idles and runs fine.
Folks have suggested that I replace the plugs and ignition coils, which I have done, but the issue is still there. I can tell the engine idles better, etc... after changing the plugs and ignition coils, but the surging issue remains.
I have a received a check engine light a few times, but not that often. The codes state misfire on all 4 cylinders, and a code for something valve over timing / performance. Since the plug and ignition coil change, no check engine lights or codes since.
Can someone please help me out on what this may be? I appreciate the help. Like I said, after the engines warm, it runs as normal.
Thanks in advance for the help.
Ed
Discussion Starter #2
Uh Oh... I think I am in big trouble if no one on here even has a guess. I will keep folks posted if / when this is resolved...
sound like a sensor or variable valve actuator timing issue. I think you are going to have to plug it into a diagnostic machine.
Can anyone tell me where the VVT solenoid is located on a 2015 Passat 1.8 motor, and if this is can be replaced by a normal user?
Sorry, but mechanic found the issue after reviewing for an hour or so, not sure exactly what pointed them to that exact component, but it surely resolved the issue.
1 - 8 of 8 Posts
