Hello, I have a 2014 Passat TDI, recently I changed EGR Valve and had DPF professionally cleaned, after the changes i want to reset the Check Engine Light and the DPF light and have no success of resetting it, any input and help why this cannot be done using VAG? My recent log is below.
I do not have power on the car and that is why i performed these repair and want to reset the light.
Monday,12,October,2020,22:27:02:52536
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.2.0 (x64)
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: 1VWCN7A3XEC088123 License Plate: MAAZ20201012
Mileage: 275240km-171026mi Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
52 56 62 72 75 77
VIN: 1VWCN7A3XEC088123 Mileage: 275240km-171026miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
75-Telematics -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CKRA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 997 009 J HW: 03L 907 309 S
Component: R4 2.0l TDI H24 9982
Revision: 71H24--- Serial number:
Coding: 001D0012042400008000
Shop #: WSC 26115 444 00000
ASAM Dataset: EV_ECM20TDI01103L997009J 004005
ROD: EV_ECM20TDI01103L997009H.rod
VCID: 3B7F4A9CB2A8985E06-806E
1 Fault Found:
5188 - Diesel Particle Filter
P2463 00 [175] - Excessive Soot Accumulation
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 275172 km
Date: 2020.10.12
Time: 21:20:15
Engine speed: 832.50 /min
Normed load value: 20.8 %
Vehicle speed: 0 km/h
Coolant temperature: 62 °C
Intake air temperature: 36 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.140 V
Unlearning counter according OBD: 40
Zähler der Regenerationszeit des Partikelfilters: 0.00 s
Particle filter: kilometers since last regeneration: 4760865 m
Particle filter: soot mass measured: -8.16 g
Particle filter: soot mass calculated: 42.49 g
Particle filter: differential pressure: dynamic offset: 2 hPa
Readiness: 1 1 0 1 1
Was the cleaning done as a result of your diagnosis and by your direction, or was it diagnosed and proposed by a repair shop to fix the condition? If the former, talk to the shop and see if they can fix it. If the latter, kindly advise them that their proposed repair did not work and they have some more work to do to make it whole.
It was done on my direction as i had the DPF light on, after cleaning i want to reset the light and i am not able to do so. Question is why i cannot reset the light?
From what I can see the OP is probably NOT using a Ross-Tech unit. With a genuine Ross-Tech unit you can join their forum website and get help from Uwe, one of their techs.
