1 - 3 of 3 Posts
Hi Guys,
I'am replacing my Automatic transmission in my 2012 Passat Tdi SEL with transmission code NRT(mechatronic failed) but I'am having difficulty finding this code for a good price but i have found three transmissions with different codes that are signifigantly cheaper. One of them out of a 2011 golf TDi with Trans code MSV, another one i found is out of a 2013 passat tdi Trans Code PBF and the last one I found is out of a 2011 Jetta Tdi Trans code MSV these three transmission range from $400-$800 while the NRT code transmission is $1800 in my area. I tried doing some research myself and i believe it is the gear ratios that make the compatibility difference but I really want to get a better opinion please let me know if you know whether or not any of these transmission will work with my car.
Thank You
1 - 3 of 3 Posts
