1 - 2 of 2 Posts
so I am a do it yourself mechanic and I changed the timing belt and thermostat and thermostat housing on my car and it took a little bit to get it started up because I had some fuel lines disconnected but once I get started it ran and then I brought it back and shut it off and I was gonna check the codes on it and it won’t start back up and it’s been a battle to get it started ever since it’ll start and run for about a second and a half and then shut off and I’ll probably do that for close to 10 times and then from there it’ll finally start up and then I’ll run until i shut it off and then It’ll have issues again. The codes it has on are P0111 P026A and P0183 would any of these be related to the problem
Double check every wiring connection you may have messed with. Heck, just check everyone you can find.
Check this link out.
1 - 2 of 2 Posts
