1 - 2 of 2 Posts
Looking to purchase a set of Zuki 18x8 wheels. 5x112 with a +35mm offset. Will they fit. And can anyone tell me whats a good tire size to put on them. Looking for a wider look but i dont want and rubbing issues.
They should fit no problem in that setup. I ran a similar setup with a +37mm offset without any issues on a B5, so i would say yes. I ran a 225/40/18 on mine, no rubbing whatsoever. You can always use the following site, great for this type of questions. On top of the page you can input your current set and then input the set you want to use and it will show you if it does fit or not! Good luck on that.
https://www.willtheyfit.com/
1 - 2 of 2 Posts
