Wondering if these will fit, they are 18"x8, 57.1 Center Bore with a +41 offset. I think they will, however what would be a reasonable size tire to run without throwing the speedo off too much, and preventing rubbing?
They should fit great. For tires, a 225/40/18 will be the correct size for the speedo and should not rub. You might be able to go with a 235/40/18 if you have a B5.5
Awesome thanks, I was concerned about the offset as I do not really want to use spacers. I was also watching a set of 18x8 et 48 Audi B8 wheels which I was told would need a 10mm hub-centric spacer in order to fit. Same tire size as you mentioned. I guess the et41 offset must just fit and that extra 7mm on the et48 wheels cause interference issues?
The B5 had 45mm offset, the B5.5 had 37 (or so), but the B5.5 has bigger wheel wells and can fit a larger tire up front. With the wider width, the high offset of a 48et wheel would rub on the inner fender liner. I think the B5 Passat looks best with a 35et, no excess camber or stretch needed. Not sure how high the B5.5 could go to equal that.
